Z3 Cranks but sometimes does not start.
bonbon
Israel
19L Auto
Ok - finally changed out the fuel pump. Surprised to find that the pump’s one way valve is fine. So I assume the fault was a weak pump. Perhaps there was not enough pressure to start reliably - but was fine to drive.
All ok now - you learn every day.
bonbon
Israel
19L Auto
Next morn - not ok.
What I did learn is that it ain’t over until the fat lady sings. Problem still persisting. Nothing to do with the pump or its return valve. Will continue the search. Cranks - but need to play games for it to start (ps - it’s not the starter either - it was just sorted recently).
Any news bright ideas?!
bonbon
Israel
19L Auto
Ok - this is embarrassing so please 🙏 nobody take the P.
I did a bit more research (which I seemed to have missed in my search 9+ months ago) and found that vac leaks can cause cold start problems.
Had a closer look at my M44 inlet piping and found a cut on the underside of the smaller pipe that exits the MAF boot. Pics attached.
I’ll know next cold start as I’ll tape it up until I get a replacement pipe. It’s driving me crazy.🤪
bonbon
Israel
19L Auto
The fat lady sang. All sorted. It was the non visible tear in the pipe. ( pic above).
End of a 10 month saga 🥴
To be fair - I also removed and cleaned the idle control valve to feel useful. Not sure if or how much it contributed.
May us all have a good year!
frankmasterjam
leeds
where is the starter relay and what does LHD mean?
Ok - first 24 hours was erratic - but seems to have settled down.
Next steps:
1. Continue to monitor before deciding to remove the one way valve (as the way I put it in there is a 180degree bend in pipe and I fear at some point it will bend and limit flow).
2. Try replacing the starter relay - next to my left knee (LHD)
3. One other failure mechanism reported has been the ignition switch. I’ll see how things get on.
4. For completion: the camshaft sensor has solved this issue for some (even though no codes were thrown)
5. If/when I remove the one-way valve, I guess I’lll need to replace the fuel pump as the one way valve is failing.
I’ll update.
