Cheers Jonco. will do. Sorry yours are coming through again. I'm hoping light use & overnight garaging will help prevent more acne
Time is my enemy at the moment, I need the car Monday to Friday, My re-thought intention now is to SORN the Zed at the end of September, get a Audi A4 Carbrilolet (Fancied one for a while) for General Family Trips, strip all the panels off the Zed and complete a full rebuild of body and running gear, so my fix is a temp one at the moment, problem I had was the the screws holding the wheel liner on were a pig to get off without grinding them I did not have a 8mm socket suitable (the socket needs to be very shallow to lock onto the nuts correctly), so time beat me.Good progress Jim. I did complete liners and sill removal last time treating them with Kurust followed by Zinc oxide primer and Hammerite. The front edges need doing again so I have just ordered some Rust Bullet as per your recommendation.
Are you still intending to take the panels off? If not, I would recommend that you at least take the wheel arch liner out to see what's going on in the lower areas behind them.
That's the problem with it being a daily driver. My plan is to do it over the winter, slow time, and do a proper job.Time is my enemy at the moment, I need the car Monday to Friday, My re-thought intention now is to SORN the Zed at the end of September, get a Audi A4 Carbrilolet (Fancied one for a while) for General Family Trips, strip all the panels off the Zed and complete a full rebuild of body and running gear, so my fix is a temp one at the moment, problem I had was the the screws holding the wheel liner on were a pig to get off without grinding them I did not have a 8mm socket suitable (the socket needs to be very shallow to lock onto the nuts correctly), so time beat me.
Sound plan - looking at your `before' pics there will be some internal work to do. I must have been lucky (for a change) as my liner screws came out quite easily with a socket and driver. They'll be coming off again in the next few weeks so I hope they are as easy.Time is my enemy at the moment, I need the car Monday to Friday, My re-thought intention now is to SORN the Zed at the end of September, get a Audi A4 Carbrilolet (Fancied one for a while) for General Family Trips, strip all the panels off the Zed and complete a full rebuild of body and running gear, so my fix is a temp one at the moment, problem I had was the the screws holding the wheel liner on were a pig to get off without grinding them I did not have a 8mm socket suitable (the socket needs to be very shallow to lock onto the nuts correctly), so time beat me.
Checked wing panel today Waxoil treatment still looked intact from inside with slight pimpling on bottom outer edge.......... Treated mine 2.5 years ago but a lone pimple has re-appearedand needs treating before it spreads into a rash........
