What’s a good code reader for my Z3?
A picture of all the ports would clear up any doubt?
ktnez99
West Midlands
Z3 2.8L
That laptop you posted the link for will probably only have usb ports think you need one with old style serial port due to age of your car to connect and run software
Thanks @colb - am looking again later on and thanks for this advice.
ktnez99
West Midlands
Z3 2.8L
I’ve asked for photographs of the ports and will continue to look this evening. Thanks for highlighting this Tony. Much appreciated.
ktnez99
West Midlands
Z3 2.8L
So…when I locate a suitable XP laptop, how do I go about finding the relevant software please?!?
the Nefyn cat
2.2i Sport
Just found this on the Web, prices vary but they have serial ports
Its an early car with OBD1 so Creator probably won't read it, he is looking at alternative using a laptop but needs one with a Serial port not a USB. Should be able to put INPA on it and read the car using the serial port.
Ian gave me this one some years ago. I've never used it, if it's any use you are welcome to it.
ktnez99
West Midlands
Z3 2.8L
ktnez99
West Midlands
Z3 2.8L
ktnez99
West Midlands
Z3 2.8L
I’m of the opinion that I’m going to not rely on garages that simply don’t have the ability to scan and diagnose issues with my car and this will only become more common place as time goes on. I’m going to get what’s needed so I can pinpoint problems as and when they arise.
ktnez99
West Midlands
Z3 2.8L
Under the steering wheel is an OBDII as well as the circular 16/20 pin port under the bonnet. Been able to resolve the air bag light that was on and put out this warning light on the dash from the latter circular port with a small scanner I’ve had a while but this scanner won’t read much including the ASC and abs.
Pingu
This may help, or it may just create more confusion...
Software and connectors. You will also need an extension cable unless you want to work on top of your engine. I extented the RS232 lead using three lengths of telephone cable (each telephone cable has four wires, you need nine wires to extend the RS232).
This is how you install INPA. It ain't easy, but follow the instructions to the letter, and it should work...
To download the Testo ZIP file, click the link below (8.7Mb)...
https://www.porterbility.co.uk/Files/EXE/testo.zip
Here are the Excel files that I use to "graph the data" (they have macros [do not use them if you think they may be unsafe]). If you prefer, you can download the bare file (without macros) and install the macros after confirming they are safe.
Excel
https://www.porterbility.co.uk/Files/XLS/DATA.xlsm
Excel97
http://www.porterbility.co.uk/Files/XLS/DATA_97.xls
Excel (without macros)
http://www.porterbility.co.uk/Files/XLS/DATA.xlsx
Macros (for DATA.xlsx - remember to save as DATA.xlsm after installing macros)
https://www.porterbility.co.uk/Files/XLS/DATA_Module1.txt
https://www.porterbility.co.uk/Files/XLS/DATA_Module2.txt
https://www.porterbility.co.uk/Files/XLS/DATA_Module3.txt
https://www.porterbility.co.uk/Files/XLS/DATA_Module4.txt
Macros (for DATA_97.xls)
https://www.porterbility.co.uk/Files/XLS/DATA_97_Module1.txt
https://www.porterbility.co.uk/Files/XLS/DATA_97_Module2.txt
https://www.porterbility.co.uk/Files/XLS/DATA_97_Module3.txt
https://www.porterbility.co.uk/Files/XLS/DATA_97_Module4.txt
I thought that the earliest Zs didn't have the OBD2 port under the dash (which, by the way, only reads engine and Auto g/box codes.
ktnez99
West Midlands
Z3 2.8L
I’ll photograph it in daylight and post it here but pretty certain it is as the garages have called it such…but then…😂
Pingu
A top tip. Once you have your laptop, only use it for your BMW, but you can add lots of stuff.
I have...
Wiring Diagrams
BMW TIS - this is THE bible workshop manual. It has EVERYTHING that the BMW techician has available.
BMW ETK - this is the BMW parts list. It is not really required now that we have RealOEM, but it can be used for more advanced searches
BMW EBA - this is all the optional extras, and their installation instructions
BMW Technical Manuals - these are the instructional notes from the BMW technical syllabus
There's another one whose name I can't remember. It gives all the times for BMW jobs.
As it is an XP - DO NOT connect it to the internet. The XP laptop will need a CD drive, a DVD drive or an USB port. You will also need a CD writer, DVD writer or a USB stick to transfer data from the internet to the XP computer.
ktnez99
West Midlands
Z3 2.8L
I have...
Wiring Diagrams
Thanks @Pingu I had a CD writer and got rid of it!!! Great advice so many thanks. I’ve a lot to look into.
GZed
Shrewsbury, Shropshire
Z3 2.8 Prefacelift
Hi Colin & Dawn. The cut-off date between ‘early’ and ‘ later’ in terms of OBD 1 and 2 is March 1998, so Creator should be ok on your Dec 98 build car..? The definitive ‘ How to’ guide on all of this is by @NZ00Z3 in the knowledge base. (If I knew how to post a link to it I would)
Before I knew any of this I bought a Creator 310 + for my Sept 97 build 2.8 but it was no good for diagnosing the same problems Dawn has. I still have it, so Dawn you’re welcome to borrow it to see if it works, before you spend money on anything else. (I would say you could have it but I now have Gookah’s 2.8 so I’m keeping it for whenever any of Gookah’s fabulous workmanship breaks down😀)
Dawn, I’m Shrewsbury and I believe you’re Wolverhampton so not a million miles away. If you’re interested in borrowing it PM me and we can make arrangements.
ktnez99
West Midlands
Z3 2.8L
Thanks! What a fab offer. I’ll definitely take you up on your generous invite to loan it. I’ll PM you.
