where about on the car is this ??
been out looking at my 1.9 and can’t find it
the right side engine mount mate..there's a tab thatthe earth strap bolts to..where does your 1.9 bolt to?Maybe there's some kind of clip with nut attached something like this and it dropped off under the car.
Maybe put the bolt in from underneath and put a nut on from the top to hold the bolt in place. Then slot the cable onto the bolt followed by another nut to tighten it up.
cMaybe there was some kind of clip with nut attached something like this and it dropped off under the car.
I'll give it a go but can only get two fingers the undersideCan’t you just put a flanged nut the other side?
you're fine mate...I have Mrs B to make sure my finger is in the right place!Want me to lay under the car and put a finger on the bolt to hold it in place while you tighten it up ?![]()
you're fine mate...I have Mrs B to make sure my finger is in the right place!![]()
yeah I've got to the point (after much swearing) where I could get the bolt in the flange with an extendable magnet, get it so I could hold it there with the tip of my finger but if I remotely even breathed it would drop out. Hence I'm exploring a bit of supergluePush it in from underneath and hold it with a finger . . The shoulders on the hex head will stop it turning as you turn the nut from above. . . Or something like that.
you'd never get a rivnut down there mate. It takes two long extension bars just to get close. underneath the wishbone really prevents any decent accessHow about a Rivnut if that don’t work?
that's exactly what I'm going try nexr mate. I tried with a bit of wood and my telescopic pencil magnet....I got to a point where I got so fed up I chucked my tools in the garage and resorted to alcoholpush the bolt up from underneath and hold it in place with a lump of blue tack then carefully put the earth cable and nut on from the top ???
thanks @ChrisD .. I'm getting a healthy 12.6v everywhere, when I crank it drops to 10v or a bit below. I've swapped the EWS relay with the unloader relay and still nothing. It only fires briefly when I unplug the ICV and TPS plugs then shuts down. really bugging me nowA KL30 error indicates that the permanent supply to the engine control unit is at fault. I’d start at the fuse box. My Bentley manual shows the permanent supply coming in via fuse 18 - check there’s always 12V on both sides of the fuse. This line goes to the MAF (pin 3) so that’s an easy place to check that the voltage is stable. Check all other earth points are good also. Good luck with chasing it down!
