well today
WAS going to be weld day !.... psyched myself up...was going to quickly mow the lawn as a warm up..... until I realised that while the washing machine was on, the draining water was going all over the patio.... blocked drain ! the bit by the kitchen door and shed was under an inch of water and sludge which had built up (
we don't use the kitchen door). So after emptying and moving the plastic shed, table, plant pots etc... I had the "
joy" of unblocking it. That seriously ate into welding time..so mowed the lawn and decided to practice welding again instead...
right... first things first... I ditched the shroud which made a hell of a lot of difference, and turned my helmet down to 10... again, massive difference... I could actually see !! (
you don't need a protective shroud for flux core as there's no gas )
First up was butt joints again.....
and ...not too shabby !.....there was one blow through, and that was because of that gap above the top magnet. Just shows you can't have any gaps with flux core. The bottom bit was me upping the voltage a bit
So that's about
19v and about 5
m/min for 1.6mm steel
Then I tried some lap joints which are FAR more forgiving !!!
Here's a side view of the joint welded
Then tried welding a patch over a "damaged" area, again lap welded..
and another one... getting a bit over confident by holding it while tacking it in place
I then used a pin hammer to hammer the patch to the contour of the "damaged" part
and there you go. Upped the voltage a bit to get the "
sizzling bacon" sound
Think I'm running out of excuses now for not cracking on with the Sills !!!
