- Joined
- Dec 8, 2011
- Points
- 165
As anyone who does performance mods should know, keeping the intake air temperature low and the exhaust gas temperature high are two of the many improvements that you can make.
I've just done a mod to keep the intake temp low and TestO proves that it works!!!
Intake Temp Graph before...
You can see that the green line (Intake Temperature) went up and was generally about 10°C above ambient.
Max Air Mass was 840.25
Max Injection Time was 13.775
Intake Temp Graphs after...
This was the drive to work. It took 12 minutes and the intake temp rose by only 4°C.
I left work 14 minutes later (the intake temp had risen to 36°C) and in the 5 minutes that it took to drive to the petrol station, the temp had dropped to 29°C.
It took 5 minutes to fill-up and the temp had risen to 41°C. I then took it for a gentle drive and the temp dropped to 23°C. I gave it a blast (you can see when by the two blips in coolant temp). There was a negligible effect on intake temp and it kept going down. Previous blasts have made the intake temp rise, but not fall. The implication is that a new cool charge of air cools the hot charge as I have managed to keep the plenum cool. Previously, the latent heat in the hot plenum heated the new charge. The casual drive home saw the coolant temp rise (as before), but the rise in the intake temp was much more gradual than before.
What effect has this had on horse power?
I don't know the new horse power, but the new Air Mass and Fuel Times look good (previous values in brackets)...
Max Air Mass = 860.5 (840.25)
Max Injection Time = 14.859 (13.775)
I really need to take the car on the same test route as before to prove absolutely that the mod is an improvement.
and knock it into neutral and record the speed and time as it decelerates.
