TestO Datalogger - what do you think?
Hello Pingu,
I try to use your Excel file but it doesn't work.
I tried everything, but it's impossible.
Could you check my testo log .csv file, and tell me if I do something bad, or tell me what I have exactly to do to make it work.
Thank you so much
Hello Pingu,
Thank you so much
The spreadsheet that I posted was for data from a different dataset. Here is your data pasted into an old spreadsheet I had...
(the file is 4Mb)
http://www.porterbility.co.uk/Files/XLS/2017-10-07-180150_jcafe.xlsx
Here is the data that I have not loaded, as it was not part of my original spreadsheet...
http://www.porterbility.co.uk/Files/XLS/2017-10-07-180150_jcafe.csv
Thank you so much ! And now, if I want to load new data, what have I to do ? Have I to copy past each data, or is there a fast method to load all data ?
Load the module below and save the spreadsheet into an xlsm file.
http://www.porterbility.co.uk/Files/XLS/2017-10-07-180150_jcafe.txt
To load new data, copy the data saved from TestO into the appropriate column in the Raw Data sheet.
Do not delete any lines manually as they are linked to Graph Data. Use z_Delete_Data to delete your data.
You need to be in Graph Data when you run the macro a_Prepare_Data. It will copy all the data from Raw Data and it will prepare the data ready to produce the graphs.
To produce the graphs, insert the start and finish lines in the red boxes in Graph Data and run the appropriate graph macro.
Thanks you, for make a new graph Excel macro crash my Mac lol.
I will try to develop an online version (PHP/JS).
If forum members can give their testo log file. Csv, so that I could create the graph with real scales without bug
Fascinating read. This makes reading latched codes to find out what's going on a rather archaic way of diagnosing problems. How many parameters can you read out simultaneously? I guess the more you do the slower the sample rate you achieve.
Interesting that oil temp takes a lot longer than coolant to reach its max and notable that coolant blips upwards after you ease off.
Is it? Oil is denser than coolant so will warm slower.
