Sudden Whine in 1st & 2nd Gear (BMW Z4 E89 23i, Manual) – Need Expert Input
TonyKTony
Hi everyone,
I need some help diagnosing a sudden whining noise on my BMW Z4 E89 sDrive23i (N52, manual gearbox).
Symptoms:
  • The noise only happens in 1st and 2nd gear
  • Only between 1,000–2,000 rpm
  • Only under acceleration / load
  • Completely disappears above ~2000 rpm
  • Cannot be heard revving the engine in neutral
  • Appeared suddenly and has slowly gotten worse
Work already done:
  • Auxiliary belt replaced
  • Tensioner replaced
  • Gearbox oil change
What the mechanic suspects:
  • Possibly gearbox bearing noise (input shaft or secondary shaft)
  • Or low-gear gear mesh whine
  • Not engine, not belt/pulley related
Duncodin
Pontrhydyrun - in Crow Valley
M44 FrankenZed
I've heard differentials making a noise like you describe. Never heard it on a zed though - Maybe on a zed it might sound like it's coming from the gearbox because the diff is literally just behind you.
I've also heard it from gearboxes (again, not zeds) although usually it could also be felt through the gear lever, as if the gear lever was always resting on a balk ring - ie if the gear lever linkage wasn't lined up correctly - although most of my spannering experience comes from rear/mid engined cars where 'linkage' was always a nightmare.
  • Agree
Reactions: B21
