Once your brakes are bedded and finally bled you will feel the benefit of the braided hoses I'm sure.
Hopefully mate may need a hand bleeding properly but will give it another goOnce your brakes are bedded and finally bled you will feel the benefit of the braided hoses I'm sure.
As Tony said i did get the beam powder coated i did this first i thought getting another beam sorted and the bushes replaced prior to the job made sense then it was a swap rather than having to run around getting it sorted mid jobGreat job I have this to look forward to. Nice finish on the rear beam did you have it powder coated? I might have got a lucky break as well as one of the local farmers has a place with a two point lift in for £50 or so quid a week one of my other farmer mates informed.
Im sure your right I can dial the height in with spring pads so i may do that but i think it will settle abit more. The car feels great on the road i supppse its like it would have been new. It has removed every noise its ever made its been worth while.Great job Ant. Bet it feels a lot more planted. I am sure you will still get a little bit more settlement now its on its own weight
Its the biggest single job on a zed when you think about it it is half the car removed as you say a great sense of achievement when completeAwesome work @Antm72
Having done this myself I know the feeling of when it's all back together . Feels like a massive job done
Camber adjustment bushes are from Revshift (via hack engineering) or PowerflexSince my mot fail seems to be turning into a mini version of this thread....
Where did you get;
.spring pads (i want 15/20mm)
.camber adjustment bushes
.flexi hoses
Cheers
I found 21.5mm spring pads which are the largest they are found against E36Since my mot fail seems to be turning into a mini version of this thread....
Where did you get;
.flexi hoses
Cheers
