Thanks Tony its all practice so we can nail it in aday @ zedshed midlandsGreat documentation Ant. Look forwards to the built up finished pictures.
I will photo the rest as i goAnd don’t miss anything out as I will be printing all this off to use as a job sheet![]()
The general reason for cutting the exhaust is the joint further forward is in a relatively awkward place and the studs and nuts tend to be rusted solidAwesome stuff, very inspiring stuff mate. Thanks for documenting and sharing
Re: the comment about cutting the exhaust, what's the basis of this and where do you normally need to cut it? You managed to get away without having to do this, right? Cheers
I believe alot the exhaust is cut just beyond the subfame so it can drop. Some zeds have exhausts that are in more than one piece so they can just undo. Mine is just a one piece and i didn't want to cut and join it and risk a leak after paying to have it built. I did go back to the exhaust builders to add a flange but its not possible as the middle box falls to close to the subframe and it would have been a waste of time in my case.Awesome stuff, very inspiring stuff mate. Thanks for documenting and sharing
When are you taking the first booking ?Thanks Tony its all practice so we can nail it in aday @ zedshed midlands![]()
And which day would that be then??????? I could provide a practice car if you need oneThanks Tony its all practice so we can nail it in aday @ zedshed midlands![]()
Some zeds have an exhaust that is in sections so can be split to help so the subframe can clear it.Awesome stuff, very inspiring stuff mate. Thanks for documenting and sharing
Not as daunting as it seems Steve it looks drastic but its only a few bolts in reality.Top work Ant, you're a brave man, that job would scare me witless.
Just as a side note you can actually remove the subframe without removing the exhaust, sometimes this is the prefered method if the exhaust flanges look past it.And which day would that be then??????? I could provide a practice car if you need one
With regard to removing the exhaust, On mine, the exhaust has a spring loaded flange connection about midway, so I’m thinking I would only need remove the rear section.
Look forward to seeing more photos
And that's some hat too !!Great job mate, I tip my hat to you![]()
I was lucky again not a spec of rust at the manifolds not even mild surface rust so they all undid with ease.Just as a side note you can actually remove the subframe without removing the exhaust, sometimes this is the prefered method if the exhaust flanges look past it.
I just loosen the exhaust hangers so it sits lower. Then remove one swing arm with half shaft at a time. That then leaves just the beam and diff in. I then undo one pin on either side and lower with the jack. Still just as simple. It’s more an extra option if you find the exhaust tired.Guess it's a lower and slide out above the exhaust then Lee?
Totally agree some people/ garages just bung them in. The tools and parts worked out cheaper than a garage anyway.I get a lot of satisfaction making brake pipes which, when fitted, look as though they belong on the car. Some of the monstrosities I see on cars make me cringe, adequate at best.
