Top work Faheem must have been difficult working in what appears a tight work space but at least under cover.
Top job grasshopperFrom this
To this
Not bad if i say so myself
Not quite as good as this though
I dont know yet. Was looking at some youtube videos, I came across one where there was a washer both top and bottom.Do you have a closer photo. I’ve never seen discs top and bottom of the beam only on top above the nut face.@Davyhoogy Mine are blackI dont know yet. Was looking at some youtube videos, I came across one where there was a washer both top and bottom.
Might be worth getting @Lee's opinion as he's done this plenty of times.![]()
Duraflex poly bush palDo you have a closer photo. I’ve never seen discs top and bottom of the beam only on top above the nut face.
Could it be a part of the design? I’m guessing you’ve gone for a non Oem Bush brand.
Good going pal, I had the back end up today and noticed that the O/S rear wheel is rocking with the handbrake on, the N/s is solidSo, the zed is back on the road (almost)!
Got the rear subframe bolted backup on Tuesday with lots of help from @Brian4
However, I've been struggling with the exhaust and a couple of the new brake lines, which were leaking. Finally managed to finish those bits on Sunday, so undertray back on and bled the brakes.
Pedal nice and firm but shortly after I lost that feeling as I developed a "weep" at the rear o/s brake line (where it attaches to the hose).
The brakes were usable and I was loosing very, very little fluid so I managed to make it home with the zed.
On the way, noticed a terrible high pitched whirring sound from the rear o/s wheel. Which would go away at higher speeds but around 5-30mph would sound awful. I'm thinking seized calipers or brake shoes inproperly adjusted and dragging against the inner drum?
Hope its the brake shoes needing adjustment and not the caliper as I've just spent ages painting them!
Once these two issues are sorted, it'll be straight in for its MOT (hopefully)
Sounds most likely as though the back plate is catching on the brake disc Faheem.So, the zed is back on the road (almost)!
The "rocking" is just the brake shoes moving on the back plate Sean, you haven't quite got them adjusted up the same that's all. Try pulling the handbrake on click by click and comparing the two brakes for binding and then locking.Good going pal, I had the back end up today and noticed that the O/S rear wheel is rocking with the handbrake on, the N/s is solid
Had a similar thing with mine for months now, between 15-40mph, originally only when the car was hot, sounded like a window was slightly open. Now sounds like a fly buzzing in your ear and happens even when not upto temp. Checked wheels, brakes, handbrake, all sorts and can't find out what the hell it is. Drives me mad at times.On the way, noticed a terrible high pitched whirring sound from the rear o/s wheel. Which would go away at higher speeds but around 5-30mph would sound awful. I'm thinking seized calipers or brake shoes inproperly adjusted and dragging against the inner drum?
last time I worked on your car I put a fly on the parcel shelf....Had a similar thing with mine for months now, between 15-40mph, originally only when the car was hot, sounded like a window was slightly open. Now sounds like a fly buzzing in your ear and happens even when not upto temp. Checked wheels, brakes, handbrake, all sorts and can't find out what the hell it is. Drives me mad at times.
Now it'll be off for its MOT on Tuesday. Really hope it passes!! Can't wait to get it back on the road
Great news Bud, it'll fly through the test now. I think you've earned a lot of driving time for the foreseeable future. Very well done Faheem.So @t-tony was spot on, no seized caliper for me to worry about. Just the backplate catching. Sorted out a few leaks, by loosening and re-tightening at the flare to improve the seal and not a leak in sight now.
Bleeding was a pain. After being bled using gravity bleeding the pedal was definitely firmer but still some sponginess there.
Moved it up a notch and used a sealey pressure bleeder, bit better but still not to my liking.
Then used DIS and bled the abs module and did that twice. Just about got all the air out i think. Pedal is nice and firm now. Gone through about 5l of brake fluid in the processNow it'll be off for its MOT on Tuesday. Really hope it passes!! Can't wait to get it back on the road
I think that's me done with any zed work for at least 6 months.......![]()
