Yep the ABS sensor should disconnect like that. Be careful though, you dont want to squeeze the clip that holds the cable in too hard as over the years they do get brittle.
This is a basic list i think of everything that needs to be removed/disconnected:
Spare Tyre Carrier
Exhaust
Handbrake cable
Propshaft from diff
Diff sensor
Shock bolts - arm should drop
Springs
Caliper zip tied to shock
Diff Bolt
Brake pipe where they join chassis/brake caliper
ABS Sensor
Brake Pad wear sensor
Anti roll bar bracket from chassis
2 large nuts either side
4 6mm allen bolts
Might have missed a couple of bits but think that should be most of what needs to be removed.
Spare Tyre Carrier
Exhaust
Handbrake cable
Propshaft from diff
Diff sensor
Springs
Diff Bolt
ABS Sensor
4 6mm allen bolts
