Worse than your one!Thank you, Allan has been on lots of sites but we’re just worried about switching the engine, just in case it’s worse than my one , mine has only done 80000 miles![]()
Worse than your one!. Call some of the larger reputable vehicle dismantlers. These guys are local to me and excellent. Engines will come with a warranty. https://silverlake.co.uk/
Just saw this now. Did you ever get it started? Did you check if it was getting gas? Sometimes the gas gauge fails and tells you there's gas and it's empty. Happened to me once. Engines start to run rough as the fuel begins to stop flowing. Then doesn't start with no fuel. Just a thought..FrankieWe tried to jump start the car , and it turned over very well , but the car just wouldn’t start![]()
The N20 was used in every 2 litre petrol BMW from around 2010 to 2016, when it was superseded by the B48. They produced millions of N20s. They never put a B48 in an E89, as the cars went out of production just as the B48 was introduced. The 2 litre G29 Z4 uses the B48.Is the engine specific to the Z4 or was it used in other BMWs ?
There has always been a potential issue with timing chains on these engines. Usually the issues were down to the chain guides which become brittle over time and break, causing the chain to jump or stretch. There is a theory that very regular oil changes help prevent chain damage, although don't think it has ever been proven.
The guides were re-designed in around mid 2014, so for the last two years of production they were much better.
You just need to make a decision Shelly. That will depend on your budget.
Anyway, I think that you are dealing with someone who doesn't care or diesn't know.
Be carefull.
Quite the opposite, these engines are know to wear teeth and sprockets at this age, doing these tests will allow the garage to find out if its worth fixing the engine or not, If it holds vacuum you know the valves are not bent and a fresh set of sprockets n chains will see her good again, if not then its new engine or rebuild but all boils down to the budget of the owner.
Fair approach if I'm honest, albeit the garage is a little reluctant.
If the timing chain has skipped a tooth, why crank the engine some more and do more damage?
Why would the garage have not just taken the cam cover off and checked it visually already, though? Bent valves are easy to spot (as they are bent) and they could whip a few out and check the piston crowns too. All from doing an easy bit of work.Quite the opposite, these engines are know to wear teeth and sprockets at this age, doing these tests will allow the garage to find out if its worth fixing the engine or not, If it holds vacuum you know the valves are not bent and a fresh set of sprockets n chains will see her good again, if not then its new engine or rebuild but all boils down to the budget of the owner.
Seems they have decided it is toast by looking in the oil filler cap so far and seeing bits of chain guide. Also, I don't see how they 'know' the camchain has jumped. They seem to be presuming this by the way the engine is behaving (and probably googling N20 engine problems).
I was going to chip in last night with offering to bring my endoscope and leak down kit over to at least try and help with a diagnosis. I normally use these for my aeroplane engines, I try to avoid car engines these days! Even tested the endoscope!
Being so close, I want to help, half my head wants to come and rip it to bits for you, the other half keeps reminding me how complicated they've become, as Lee rightly highlights.![]()
