Dxbolton
New Forest
2.8 auto
I used the rear side trim of a Triumph Herald.
it tapers to a point from the front and the rear edge is nicely rounded for the back end. 3M tape holds it in place
ruan
Maybe a car jumble will turn up something that could be modified, are those grp bumpers or has anyone found chrome bumpers that will fit this kit?
Duncodin
Pontrhydyrun - in Crow Valley
M44 FrankenZed
Oh. This looks like something. Looks just the right thickness.
Old front bumper.
Cardboard template and chop out a piece
Chop it about a bit and
Bit of grinding later
All that was done with the old angle grinder. Now to get out the hand files and do some finer shaping.
Duncodin
M44 FrankenZed
Still a bit more to do. Couple bumps in the bottom surface. Thinking about a thin grommet under it maybe. Not sure yet how to attach it so it doesn't come off and go bouncing down the motorway. Maybe small screws from underneath.
Pingu
It looks a cracking job so far :thumbsup: .
It looks thick enough to take an M4 (8mm A/F nut) or, at a push M5 (10mm A/F nut) thread, so I would use two, maybe three studs, with washers and nylocs. Clearance holes 0.5mm larger than the thread will allow for alignment.
I wouldn't use bolts, as the thread may strip inside the trim.
Duncodin
M44 FrankenZed
Yeah. Gonna put two M4 studs in it.
It polished up nice. Wondering if I should laquer it or maybe that'll look naff when the laquer gets chipped. The alu should stay nice if polished now and then. Shouldn't it?
Pingu
I laquered the aluminium inserts on my dashboard, but I scoured them first. They are fine. I don't know how polished ally would look when lacquered.
ruan
Before I place my tribute order I would really like to see a 507 kit in the flesh, doesn't need to be completed, is anyone near to Reading, Berkshire?
Duncodin
M44 FrankenZed
Oh Nooooo!
Fettling a door using my big flat sander and thanking my lucky stars that the door panel is so flat and . . . No. Wait. Flat isn't a good thing.
It really is slab sided.
Bu**er. Now I can't stop my head working on a.plan to ditch the slabs.
ruan
It looks soo much better than the kitchen door that I am sanding down !
IanA
Oxon
Sarah Cox Cars Ltd in Notts have one for sale. Take a drive up there and look around.
Not cheap but the yellow one is very nicely presented.
Blue one looks good as well.
Looks as if they've been built to sell- not diy projects.
