Then you're a very lucky man, young Albert.I was after a B roadster when i fell across the zeds. Now i've ended up with you lot!![]()
Top work there mate,the owner will be well chuffed with such progressAfter showing Tony, where I had got to with his Midget I have some more strip down pictures for you. After getting the car up on stands and removing the wire wheels with the copper/hide hammer the strip down began.
With the wheel out of the way next comes the brake drum which is retained by 4 nuts on the original wheel studs, these are locked by "tab" washers to prevent loosening of the nuts.
A couple of taps freed the drums and they slid off easily. The half shaft and splined hubs for the spoked wheels are held to the bearing hub by 1 single Phillips screw, which when removed allows the half shaft to be withdrawn from the axle tube. Now I could disconnect the H/B cables and brake pipes from the cylinders and take the back plates off the end of the axle. The N/S one came off easily-ish but the O/S one I had to drill the heads off the 4 bolts and punch them out of the axle after removing the back plate.
View attachment 51277 View attachment 51278
You can see the bodge carried out by the previous owner on the brake shoes adjuster, it had been replaced by an 8mm nut and bolts which offered no adjustment of the brake shoe what so ever.
In this picture you can see the end of the tapered adjusting screw in it's location, the new shiny one in the centre of the back plate with it's 2 new wedges are what the adjuster consists of. As the screw is turned inwards by using a spanner on the outer end the taper forces the wedges out which in turn pushes the brake shoe surface closer to the drum face. So simple, but very effective. BUT,
On the O/S one there was the 8mm bolt, which really was doing absolutely nothing,
This is what I ended up with by tea time on Saturday.
View attachment 51269 View attachment 51270 View attachment 51271
I was trained to keep tools in an orderly fashion and clean. I'll hopefully get the wheel bearings and hub oil seals changed and gaskets scraped before the new pile of bits arrive later this week.
Thanks Steve, yes me and Tony had a site meeting this afternoon and he left with a list.Top work there mate,the owner will be well chuffed with such progress.
Great read Tony, I love this sort of stuffAfter showing Tony, where I had got to with his Midget I have some more strip down pictures for you. After getting the car up on stands and removing the wire wheels with the copper/hide hammer the strip down began.
Yes did a lot of courting in a midget when I was much younger and more pliable. If you know what I mean. We also campaigned an MGB GT for years until I just got fed up with repairing it all the time. Allways something that needs doing on an English sports car. But enjoyed them all immensely.You owned MG's did you not Mike @EnthuZiaZT ?
These cars were not built to do those speeds Mike.......I was going to ask about humping in a Midget, but I think I had better not...I recall slowing down urgently from 100mph
if there's a will there will be a way Mike!! JIMThese cars were not built to do those speeds Mike.......I was going to ask about humping in a Midget, but I think I had better not...![]()
Yes iam very pleased with the on going progress.Top work there mate,the owner will be well chuffed with such progress.
Nice car.When I was a kid, I loved these.....
The Sunbeam Tiger is a high-performance V8 version of the British Rootes Group'sSunbeam Alpineroadster, designed in part by American car designer and racing driver Carroll Shelby and produced from 1964 until 1967.
