Very impressive DIY skills
and if I did I would do it littlefeller style, like not bothering with a pump, all I would use is a 45 gallon drum, fill it with water, attach vac pipe to top of filled barrel, attach to vacbag with the job inside then open the tap at the bottom of the barrel, you might need a u bend at the tap to stop it taking in air, instant vac press. or I just hydrodip the console and save myself tons of work and using that glue must be right messy, I would get in a right state, probably smells nice thoughLooks great, let's see it installed please! JIM
Its still drying! And I want to put another coat on, perfection takes timewe need fitted pictures!
