hope so
Sorry no help with the INPA codes. Rear springs need both rear wheels off the ground to get the swing arms fully down or you are fighting against the rear roll bar.if only one side is jacked up the roll bar is trying to lift the wheel in the air level with the wheel on the floorto be honest, it has always had this odd stumble, i did try and swap the rear springs by myself today, it was a no go, its very difficult to get compressors in there, then when they are the right size to fit they dont have quite enough travel to compress it enough to get them out, the other option is to compress then strap, remove tool and compress some more, the problem here will be how to de-compress them, dont facy getting killed by a stupid spring.
i managed to find 2 brand new springs for £40, in there original box, purchased but never fitted by the seller.
Thanks Brian, will give it a go.Sorry no help with the INPA codes. Rear springs need both rear wheels off the ground to get the swing arms fully down or you are fighting against the rear roll bar.if only one side is jacked up the roll bar is trying to lift the wheel in the air level with the wheel on the floor
You still need to remove the lower shocker bolts though. Jack under the Diff, stands on the jacking points under the sills and then you can use your jack to raise the rear arms to re fit the shocker bolts.Thanks Brian, will give it a go.
I seem to remember @Faheem had a similar lumpy tick over and the consensus then was sticking hydraulic valve lifters. I think he was in the process of curing it by changing the oil and using a flushing oil.fuel additives can ruin a cat, im wondering if this sticky valves could actually be the reason for the misfire. no i use ordinary supermarket fuel.
while it is having this starting fit, it it not running on all cylinders, it starts and runs on about 2 then 3 then 4, while running the smoothness feature on my inps yesterday cylinder 2 and 3 were higher than 1 and 4, about twice as high though this does sometime swap around but overall the two middle cylinders are not running the same as the outer two.
once the lower shock bolt is out If you can get someone to push the swing arm down (stand on the rear handbrake drum) the spring will pull out (from the bottom not the top). Me and Gary did his last weekend, easy with two, proper bugger on your own. using a flat bar to pri the bottom out will help. new ones same approach put the top in first then the bottom once the arm is pushed down.to be honest, it has always had this odd stumble, i did try and swap the rear springs by myself today, it was a no go, its very difficult to get compressors in there, then when they are the right size to fit they dont have quite enough travel to compress it enough to get them out, the other option is to compress then strap, remove tool and compress some more, the problem here will be how to de-compress them, dont facy getting killed by a stupid spring.
thanks for the offer, but im going to use the spring fitting as bait for the mot chaponce the lower shock bolt is out If you can get someone to push the swing arm down (stand on the rear handbrake drum) the spring will pull out (from the bottom not the top). Me and Gary did his last weekend, easy with two, proper b***** on your own. using a flat bar to pri the bottom out will help. new ones same approach put the top in first then the bottom once the arm is pushed down.
If you want a hand I will come up straight from work this evening.
yep thats it.As @Brian4 has said I did have a bit of a lumpy tick over, not sure if it is similar to what you have, the car sounded something like this:View: https://youtu.be/aqo8_hI8zXE
- only on cold starts.
However, once warm it drove spot on with no issues what so ever.
Compression test on a warm engine gave some very good results, I believe it was 175PSI across all 4 cylinders, however a compression test done on a cold engine gave me numbers that were all over the place. Mainly cylinder 2 where the compression was next to nothing.
Thanks to @t-tony I was told to use some engine flush then change the oil and add in a valve lifter treatment.
I used Mobils 0w-40 and Wynns valve lifter treatment as well as their engine flush.
Car starts absolutely fine 95% of the time now, however, there is still the odd day where I get a bit of a rough idle on cold start. Once every couple of weeks... Significant improvement on what it was like before.
I'll be performing one more engine oil flush and if the symptoms remain or get worse then I'll think about a new cylinder head.
