SOLD Modified LED Indicator Relays - HOW TO
HOW TO NOW ATTACHED AS I WILL NOT BE MAKING ANY MORE
  • Cleaner more modern looks (when off and flashing)
  • No hyperflashing when using LEDs
  • No visible orange in the lenses
  • Much brighter / safe indication when using the right bulbs
  • No need to run load resistors, this is the proper way to do it
  • Plug and Play, takes less than a minute to fit and requires no tools
  • Uses premium quality components purchased from RS Components
  • Will work with any combination of LED and Standard Bulbs
Here are some pictures and a short video
The relay (looks stock apart from LED marking)
Look no Orange
Video of flashing in night and day to show the impressive light output
I bought this from FPCeuro. It is a Wehrle OEM. It looks a little different, but it works fine. The part to remove looks more likd=e part of a paper clip. Here is a photo of my modified part and the removed part. I used Sylvania LED bulbs. https://www.fcpeuro.com/products/bmw-hazard-warning-relay-oem-supplier-61361388533
