I bought this from FPCeuro. It is a Wehrle OEM. It looks a little different, but it works fine. The part to remove looks more likd=e part of a paper clip. Here is a photo of my modified part and the removed part. I used Sylvania LED bulbs. https://www.fcpeuro.com/products/bmw-hazard-warning-relay-oem-supplier-61361388533HOW TO NOW ATTACHED AS I WILL NOT BE MAKING ANY MORE
- Cleaner more modern looks (when off and flashing)
- No hyperflashing when using LEDs
- No visible orange in the lenses
- Much brighter / safe indication when using the right bulbs
- No need to run load resistors, this is the proper way to do it
- Plug and Play, takes less than a minute to fit and requires no tools
- Uses premium quality components purchased from RS Components
- Will work with any combination of LED and Standard Bulbs
Here are some pictures and a short video
The relay (looks stock apart from LED marking)
Look no Orange
Video of flashing in night and day to show the impressive light output
