len crissell
- Joined
- Nov 3, 2013
- Points
- 22
Good idea, am replacing my sills at the moment, will give this a try, plus lashings of waxyol. thank you.
Looks like I'll be taking my sills off later in the year as the front and rear trailing edges are just starting to have a bit of rust forming. One thing I was thinking of doing after refurbing/replacing the sills was to seal off the gaps with a few layers of Denso tape. For those who haven't heard of it, its used in industry to protect carbon steel fittings in exposed/extreme condition locations. Back in the 70s we used it at ICI out on the chemical plants and more recently offshore on oil installations/platforms. It really does stick like s**t to the proverbial blanket.!!!
I have some rolls in the garage from way back which I'll be using, but I've just checked online and its still available see link below, there will be other locations to source it if you do a search to get the width you want. Its available in 50mm, 75mm,100mm & 150mm wide rolls x 10mts long, so one roll will go a long way. The advantage is it sticks really well to surfaces without any mechanical fixings just press it in places and remove any air bubbles towards the edge and it self seals. I suppose if you wanted you could apply a coat of underseal to blend the colour in with wing liners etc. Wear some disposable gloves to apply and don't get it on your clothes!!
https://www.amazon.co.uk/All-Trade-...TF8&qid=1518430239&sr=8-7&keywords=denso+tape
This is Denso UK site for background information.
http://denso-tape.co.uk/
