made this out of my cig lighter usb brought of ebay for 1.99 (post above) broke it open and removed the gubbins, I will Velcro this to the top of the dash.
Very nice. I need one of those bad boysView attachment 29536 fitted, running dash cam and sat nav yeh.
Yes please. I'm feed up of my satnav leads hanging around the gear knob that would sort it out a treatthere well cheap, £1.99. will order you one if you like.
These are useful for laptops to connect multiple usb items such as mice, keyboards, printers etc - as a charging and interface tool they are very very poorWould this do the same job Littlefeller
Hi where did you get your roll hoops from ? I've got the same zed & don't mind if the top box doesn't open
thanxHi stacey, i got them from another member second hand, but they are listed new on ebay.Hi where did you get your roll hoops from ? I've got the same zed & don't mind if the top box doesn't openthanx
Hiya ,Yes I've seen them are they easy to fitHi stacey, i got them from another member second hand, but they are listed new on ebay.
Thanxyes they just push in, you need to remove the covers on the trim, then i had to make the holes a little larger in the trim, this was easly done with a file.
