I imagine when remapping though getting good fuel flow through as well as air is fundamental to getting the best results.Lots say the injectors are not needed though as all they do is just throw more fuel through?
Its the same part number as the one gookah has fitted to his, which is fitted to the 320 (2.2 M54) and the ports are definitely bigger and so is the disa compared to the 2.8 one. I wonder if this produces the same results but no one has ever gone down that route as they only believe the 325 or 330 ones fit? Yet I have just found one on eBay with the part number from the 320 which says it has been removed from a 325?!Its got 320i written on it ...lol i imagine the disa etc may be different the 3.0 is defo bigger than the 2.8 it must play its part in the upgrade.
Part number for DISA for the 330i, Z3 30, E60 inlet manifold is; 11 61 7525 752.Its the same part number as the one gookah has fitted to his, which is fitted to the 320 (2.2 M54) and the ports are definitely bigger and so is the disa compared to the 2.8 one. I wonder if this produces the same results but no one has ever gone down that route as they only believe the 325 or 330 ones fit? Yet I have just found one on eBay with the part number from the 320 which says it has been removed from a 325?!
Disa fitted to 320 2.2 manifold on left and 2.8TU on right
That number shows up on realoem as fitted to both the 320 and 325 E46's plus the 2.2 Z3's which leads me to believe that the M54 2.2 ones should also work. If the 2.5 intakes work then surely the 2.2 ones do the same if they are showing as fitting both models.Part number for DISA for the 330i, Z3 30, E60 inlet manifold is; 11 61 7525 752.
RHA, ROY.
WRONG PART NUMBER FOR DISA Should read; 11 61 7544 805, sorry I got so many part numbers under each other plus my eyes are old and tired.Part number for DISA for the 330i, Z3 30, E60 inlet manifold is; 11 61 7525 752.
RHA, ROY.
That's really good news and your persivierance has paid off, fingers crossed your Z turns out as good as mine and you'll be looking in your rear view mirror for your dad. And he'll be looking in his for me. This also means that the way you managed your engine swap your ind/mani will be on by tomorrow night.Might be worth a try at that price if it includes the DISA and ICV as pictured and its the same part number as Gookahs which seems to have worked. I've chickened out and gone for one off a 3.0 though, albeit an X5 which has the same engine code and specs as a 330. Couldn't find the part number on real oem for it though as its listed as 7523291.
From what I found the 2.5 ones have the part number 7523290 or 11617525752. So the one I have is ending 291 which I think the equivalent part number will end 753, which is the one you have Roy. Anyway its from an M54B30 as far as I know and it comes with the DISA and ICV so I will wait and see what its like when I get it. Paid £55 which will be a bargain if the DISA is correct and working otherwise I'm looking at another £80 on top. Adaptor plate cost me £22.69 direct from Bimmertune. Once fitted I can compare with Gookah to see if there is actually any difference.
I agree @Rha what I said was he needs to make sure he can supply enough air to match larger injectors IF he goes that route. If he goes to bigger injectors he has to ensure air volume is correct or will be running rich and I don't know if the computer will be capable of adjusting enough to make use of the extra fuel without remapping. JIMJim I believe it's the volume in the combustion area that it's all down to and the 2.8injectirs are just fine the purple are overkill no needed although will work, but the pressure won't be altered
Roy.
Thank you, wow the cams thats something i would want also but im in have no mechanical experience to dig that deep inside the engine. it is a junkyard so dont matter what i do w the donor car but.... let me research thank you!!I have the M54 3.0 intake manifold on my M52TU. The stock injectors can flow enough fuel in NA applications. I also have the M54 3.0 intake camshaft which is a drop in as the heads are identical. This cam has more lift and duration and still the stock injectors are enough although I strongly recommend a remap to add the additional WOT fuel you will need.
The combination of the cam and intake manifold has increased WOT airflow by 8-10% as measured by the MAF and now instead of running out of breath this thing screams to 7k and pulls hard all the way. You do seem to loose a little seat of the pants torque below 3k but in a Z thats not really an issue. In a 2.5 ton 7 series maybe.
If you do the job yourself (and I did not) make sure to be sure to label all the wires you disconnect. The guy who did mine did not and there is only two wires that can be mistakenly incorrectly connected which results in a blown fuse and a no start situation. These are the oil pressure sensor and fuel breather solenoid wiring.
The m52tu 2.8 head and the m543.0 head share a part number. Same part. Exhaust cam timing on both engines is the same but M54 3.0 intake has a mild performance intake cam which is a drop in on M52tu. At my altitude I measured about a 5% increase in airflow at WOT. You need to remap to add WOT fuel.Thank you, wow the cams thats something i would want also but im in have no mechanical experience to dig that deep inside the engine. it is a junkyard so dont matter what i do w the donor car but.... let me research thank you!!
so the m54b30 and m52tub28 is a double vanos. did u literally just drop in the heads?
i just recently did my vanos refresh. did u change anything in your vanos?
Hi there. i am closing to begin the intake swap. i am just waiting for the adapter.The m52tu 2.8 head and the m543.0 head share a part number. Same part. Exhaust cam timing on both engines is the same but M54 3.0 intake has a mild performance intake cam which is a drop in on M52tu. At my altitude I measured about a 5% increase in airflow at WOT. You need to remap to add WOT fuel.
