Hi Roy.
sorry have been away with work
I too noticed a reduction at lower revs but nowhere near as much as you are describing. 4000 rpm onwards is much quicker as you say. which for overtaking is right where I want it, as I drop a cog and it launches.
I knocked 1/2 second off my time at santa pod just by doing this, and there is no way this top end is accounting for a loss as you describe. Car is certainly not boring and I havent had a remap either, I did go into INPA and re do the adaptation though.
the remap apparently gives back the deficit at lower revs and even increases further the upper end.
Car should be giving out over 200hp now so that should certainly not be boring.
MY TB looks the same as yours and I have all 4 bolts fitted, but I was wrong, I did have to do a modification to the TB as below to clear the idle control valve.
Disa valve is a lot bigger on the new manifold. Purpose of the valve is to breathe more air at higher revs, could this be your "breathing too much air" problem at low revs if it is not working/stuck open (or not plugged in
