Hey Z'ers,
Haven't been on in a bit as my dad's been enjoying the car, using it every dry day that there's been.
Anyway, he's now away on holiday, which means, it's back with me for a while.
Got the car on Friday, and already done a few things.
First up, I've had the powerflex rear top mounts sitting here for a while, and the cars' been rolling on my old M3 mounts for the past month or two, so two bolts up top, and one from underneath and the shocks are out, swapped the top and back in they went.
View attachment 58078 View attachment 58079 View attachment 58080 View attachment 58081
The powerflex kit comes with an internal reinforcement plate, so the chassis gets sandwiched between the mounting plates.
Whilst, i was poking about underneath, I took a few minutes to drain the diff and gearbox and refill with fresh fluids.
Our gearbox has had the sticky 5th detent issue since we got it, as did my old e46 330 which had the same gearbox. Anyway, i didn't want to remove the box any time soon, so was hoping the fresh oil would get it moving, and very pleased to report that the issue is almost
away, or about 90% reduced. I used Fuchs Sintofluid 75w-80 which has proven to be top notch in my other cars too. It still catches when cold, but after a few miles, it's working perfectly.
As for the diff, I used Castrol LSD 75w-140, but I'm now getting a bit of a knock in the rear. At first I thought I mustn't have torqued the top mounts enough and the sleeve was moving, or that the poly bushes were just transferring more 'shock' noise to the cabin, but i've done a few drives since, and I'm convinced that I'm actually getting increased diff lash as a result of the fresh fluid.
Anyone else ever experienced this?
My only other thought is that after jacking the rear under the diff, that I've damaged the old fragile bushes in the diff, or even the rear axle (both of which will be getting replaced in the winter anyway).
Anyway, i've checked everything and doesn't look like anything's about to fall off any time soon, so car's back on the ground and I'm looking forward to the next sunny day to give it a run.
