Long time BMW owner/BMWCCA member, picking up a '97 2.8 Z3 this week
e30cabrio
American Zeds
Dash is in, I was waiting for bulbs that the entire center console has to be disassembled to r&r that just came so progress will resume.
__________________
e30cabrio
American Zeds
Weekend progress, wiring was not fun & caused delays.
I thought I posted that ^ this morning.
Almost.
Esteban
American Zeds
USA
CM93, BT93
Be careful reinstalling the row of switches in the center console. The thin plastic between each switch can break easily.
e30cabrio
American Zeds
You'll be happy there when its never under 90 and upwards of 120+ here.
Mad dogs and Arizonans go out in the midday sun!
e30cabrio
American Zeds
This happened today.
I'm blowing oil from the bottom of the dipstick tube & it's hitting the cat & looked like burning oil, scared me before I verified that was what is happening.
e30cabrio
American Zeds
Thanks to finally having boost, my 27 year old dipstick tube O ring failed & blew oil onto the cat scaring the crap out of me with billowing blue smoke. I cleaned it up & replaced the O ring.
So far so good.
[IMG]
[IMG]
[IMG]
e30cabrio
American Zeds
Looks like I blew a cylinder.
Did a compression test and am 10 to 15 lbs lower than before the SC ( was 188-195) on the still good cylinders (175-185) but have 125 on 3. Oil on top of most pistons 3 is the worst.
e30cabrio
American Zeds
Another oddity, no blue smoke until temp is at 1/4.
Here are the plugs. (in for under 300 miles).
[IMG]
[IMG]
[IMG]
Only 1 of those running clean and dry. 2nd from the right You have problems.
e30cabrio
American Zeds
I can get an iron block M52 328 motor, is the weight penalty a problem?
I would have no idea to be honest. I guess you'll need to peruse the BMW forums at home.
Esteban
American Zeds
USA
CM93, BT93
This is subjective. Some folks don’t notice a difference. Others much prefer the lighter cars. What is the difference in price for iron vs alu?
e30cabrio
American Zeds
I can get the iron one 1/2 the Aluminum (1k for iron, 2 for aluminum) The iron positive is more boost, negative is weight.
e30cabrio
American Zeds
It was suggested I do another compression test with all plugs out. Here's what I have: Also, the smoke is worse.
You should always carry out comp. tests with all plugs out. I assumed that you would've done.
