Getting a bit stiffer...
Bonzeau
Aylsham, Norfolk
Z3 2.8 litre Roadster
It's fixed to the threaded ends of rear axle carrier via spacers and custom nuts.
BlackBMWs
Check twice, fix once...
Sacramento, California
Z3 1.9L, 2.3L
The bottom rear brace is attached to the Subframe studs via spacers and a special extended nut. The body braces are attached at the front at the Xbrace, with a longer bolt and at the rear, it attaches to the required rear strut brace via nuts, bolts and washers.
Took it on a mountain run this last weekend. So solid it increases my confidence on these very tight turns. I can compare the driving feel of my two Z3s and the difference is definately noticible when driven hard. Or over bumpy roads... Aside from the reduce clearance, i do like this mod and glad the car has it.
Bonzeau
Aylsham, Norfolk
Agreed! I do check the torque of all the fixings from time to time, not that any have dropped, just to be sure all is as should be.
Bonzo.
