For the Love of my Zed! Novice vs Car
Excellent progress thread, well done. :thumbsup:
Today is etch and paint day . . .finally, much cleaner than derusting. (Ill pretend for today that the car and tank straps don’t need doing:whistle:), so all the pieces out and metal prep . . .
Then time for painting, i went with POR15 which I’m glad to say has been a dream to apply, the consistency is great and I’m surprised at how far the tiny tins go application wise . . . I managed to apply a coat to all the below with less than 1.5 tins
So, loads of bits done, cant wait to put it all together with bushes and new nuts n bolts . . .alas, might be trying to change a clutch and still need to derust the chassis so installation will have to wait. . .:whistle:
Used the above caliper paint and its a paint brush type . . . Needs about 4 coats to be good but the amount that came in the tin is enough for 2+ cars front and back. I’ve got some spray lacquer to finish it off . . .racing red, going to make me twice as fast and brake in 1/2 the distance=))
Had another look at the brake lines and glad to see the brake lines are easy to undo at the ASC.
So a question for you more knowledgable. . . Regarding welding spots in the boot . . .it looks like 3 have popped (add it to the list) and in your (the knowledgable), does this need attention?
1) Is there a thread you can direct me to to see how the weld strengthening should be carried out?
2) any recommendations of places near Gatwick or in south London?
3) what tequnique do they use? Arc welding . . .?
4) if so, what AMP do you need, (another skill i could acquire, #£50 for an arcwelding kit)
Mmm, on second thought, anyone know how much a strengthening weld job would cost?
Welding is a real art and not easy.
I have a small arc welder but not the skill yet, so I would never let myself loose on my Zed !!=))
Mine uses welding rods, and in hindsight wish I had bought a small MIG welder (wire feed )
You watched me process that!, always have wanted to learn the skill, just not sure if i want to learn on my Zed:stop:
So, i got excited and decided to put rear trailing are bushes in . . .mmm its a tight fit and after having to use a rubber mallet they keep slipping out, so beam bushes in, grabbed a beer and tomorrow is another day!
