Does anybody know the part number for this please?
NickUK
Cheshire
Sorry that's a bit late but good luck. I think I'm just going to make do with the one I have as it's just about doing its job still.
Chrisr1949
Southport UK
Have you tried putting it on the anvill of a bench vice and hammering hell out of it, the high spots will be flattened back down to somewhere near where they should be.
NickUK
Cheshire
I did that to a certain extent but just by squeezing it with some pliers.
Well worth trying what Chris suggests, Use a flat faced lump hammer if you have one.
Sean d
Lincolnshire
Not quite sure what all the fuss is about, just use individual washers, if your careful and the thread is good the cables will not twist, after all your only adjusting the hand brake
NickUK
Cheshire
I'm my case, the nuts were snagging slightly on the thread enough to try and twist it. I know some car parts are unnecessary but that double washer is there for a reason.
Mazza
Bognor Regis
Z3 1.9 M44 Roadster Z3 2.8 Roadster
@NickUK
Took dimensions from the pictures you posted, and used a bit of ‘ creative engineering’. =))
Started with a bit of brass.
And came up with this
This was my first attempt, but it looks similar :whistle:
If you want to try it, send me a PM with your address. Being brass its easy to file so if the slots need to be enlarged its not difficult to do. ( I can’t test on mine as the brake cables dont have the flats on.)
NickUK
Cheshire
@NickUK
That looks like a job well done to me. I have used my old one currently as it seemed to be holding the cables, just!
