After the failed MOT, and losing a mechanic I thought I could trust, I decided that I would carry out the repairs myself. This meant I could use the money I would be saving on labour costs to make a couple of upgrades.
First, I picked up a set of Powerflex lollipop bushes from Amazon Prime (I'm a Prime addict). I figured that these would be easier to install than OEM bushes. I'm not sure if I was right or wrong!
I sourced a set of used bushes to work on and have ready for when I carried out the work under the car, and began to remove the old, worn bushes. After a LOT of work with the hacksaw and a club hammer (not at the same time!) this happened:
I don't own a press, so I took the bushing carriers into work with me, and used a very awkward wood vice (in the construction classroom) to press the polyurethane bushes into the carrier:
That was all the progress made until the weekend...
Car up on stands and dirty undertray off:
Then, on each side there were:
2 bolts for the lollipops
1 nut for upper ball joint
1 nut for the lower ball joint
And with more club hammer action, combined with a ball joint splitter, both control arms/wishbones came off:
Time to reassemble and install. I chose to replace the control arms, with Meyle HD control arms for 3 reasons:
- Great price
- Positive reviews
- I liked the idea that if a ball joint goes in the future, I should be able to remove that and replace instead of buying a whole new arm. Although this sounds like a lot of extra work.
The upper ball joint nuts were a pig to tighten up, as there was very little room to swing a spanner. I told
@t-tony that a titereach would've been perfect. Andrea saw that message to him and thought I was cheating on her, until I explained!
Undertray back on, wheels cleaned off the car, and replaced and that was the front end done!
As a side note, either the weather on the south coast has corroded my new drop links in 6 months or my (mentioned above) "trusted" mechanic never actually replaced them when I paid him to!
Rear springs next!
