My Touareg had them where you could have them on permanently and I found it distracting to be honest Malc.I was thinking about it......but not a good idea???
I think if you were driving down the road with a RED glow coming from your car interior you could possibly get some farther strange proportions , ( like how much for a quickyI was thinking about it......but not a good idea???
)It would be more than strange if they propositioned a 60yr old for a quickie. How can a 60yr old do anything quick?I think if you were driving down the road with a RED glow coming from your car interior you could possibly get some farther strange proportions , ( like how much for a quicky)
Mate when you get to 60 there are somethings you don't hang about withIt would be more than strange if they propositioned a 60yr old for a quickie. How can a 60yr old do anything quick?![]()
Hi
I was going to use that cable for the remote opening of my boot, however its much easier to use the a post connection for footwell lightsOooh.....like the look of that
The following info courtesy of @Sean d ( I think). Identifies the wire to connect to. X13252 being the ref on the circuit diagram above.......may have just cracked it
behind your glove box is the ZKE unit with 3 plugs. Black, Yellow, Green. (yellow may be changed to a purple plug on facelift)
On the left hand side is a black plug which is X13252 connection
You will need to link in to terminal 4, which is the Brown/Black wire. (Bottom row of plug 4th from right) This outputs +4 to +12 volts giving the brightening/dimming result.
Yes, that's right Malc, pin 4@Mint I think that ties up with this diagram I found created by @littlefeller on an old thread.
Just need to identify plug A104 and terminal 4 brown/black wire !
I think the glove box is coming off tomorrow.Hi
