Update 15 - Brake Protection Plates Part 1
So Last weekend (11/5/15) I started the dreaded Brake protection plate replacement, seems an awful lot of work to change a simple metal disc but I have no choice. For a while now I have had a work around which held the rear handbrake shoes to the brake protection plate, this work around has been quite successful but it failed again the other day prompting me to sort the problem once and for all. I took some pics on the way
As our cars become older some pieces start to fail and the tin worm even sets it, below is a picture of a rear handbrake shoe that has lost its retaining clip and spring…….Again. With the clip and spring away the handbrake shoe can rub up against the inner drum part of the brake disc giving the most horrendous squealing sound!
Pushing back the drive shaft out of the hub, the stud kit and wheel spacer came in really handy for this
I made two small brake hose adaptors to attach to the rear brake pipes, this stops fluid dripping everywhere.
Here they are in use, not the exhaust hanger is removed for easy access.
After several hours of disconnecting nuts/bolts/brake pipes/cables/connectors you end up like this.
Rear trailing arm on the bench, hub removed from the wheel bearing and brake protection plate removed, note I had a bolt in each trailing arm snap
….. what to do?
Drill it out, tap the new hole and fit a helicoil.
Jobs a good un
More to come.
