Yes you must be getting close to the finishing line now Mazza, it will be a lovley car when done.
I'd be buzzing
I'd be buzzing
Not surprised that you're retired hurt after all, what you've been doing is Exaust-ing.Just a small update as I did get underneath the car this morning (until I over stretched and pulled the muscle in my shoulder again )
Wasn’t intending to do much more anyway other than see how the new exhaust fits.
Having crawled underneath, I am a bit concerned that over time the car has dropped on the 4 axle stands.....My belly now keeps hitting the underside of the car
Anyway...
Bit of a struggle trying to manoeuvre that large lump of dead weight underneath the car .....but once I was under, the exhaust was easy to pull in and lift up onto axle stands
Front connections line up ok
The gearbox mount lined up ....but will just need a bit of a tweak , and probably easier to bend the arm rather than the exhaust bracket.
Must remember to remove the cardboard
There is a bracket missing from the exhaust, so I will have to sort out a solution which may mean taking off the beam bracket and replacing it with just a stud of some sort ( I have a cunning plan!)
Overall not bad, and fits with good clearances, so not bad for just under £240.
Rear Box fits correctly onto the pipe with the joining piece supplied
And locates with a nice even clearance over the top
Life expectancy on a mild steel system is about 3-4 years ....going to try some paint, after a recommendation, and just as an experiment
The whole exhaust and any brackets will be sprayed matt black.
I dont expect it will stop it rusting ....but may slow it down a bit.
That was it for today...retired hurt , but not so much that I can’t nip down the pub
Oh , and the threaded bosses after the two cats were correct as I tried one of the sensors to make sure.
You’d think that as you get older you would learn to not to do things like that…… no bloody chance !!!Ouch, that’s look bloody painful Malc. When Shirl’s old dad was still working he regularly had cuts and lumps on his swede.
Is that litmus paper in the bottle - to tell you what % it is -I had a plan to do bits and pieces between the footy games……
So went out to connect up all the brake hoses… needed to add a washer as the braided hoses have longer threads that std ones so there is a bit of movement.
Just a std M14 BZP washer
But didnt go as planned aI smacked my head on a sharp part of the car !!!
But medicine at hand…
(Aldi special !!!)
still now only 2 to do … then bleed the system ( and not my head)
