Moved a bit further forward today…. and all it took was a drive to ZSHQ….
My contribution was carrying the bits from the car to the bench, and then watched while Lee and Gaz assembled the parts…. And then only because Lee luckily had the two top washers that I had forgotten to take with me.
and just as well, as looking on my bench, the caps are there but no washers…..ooops must have mislaid them into the scrap bin
Then I noticed that the second assembly didn’t seem to sit right…. So it was stripped down to find the top plate was bent
The centre area on the right hand side of the hole has been bent upwards. ( Pothole damage????)
Again luck was on my side as Lee had a powder coated plate in his box of refurbished spares so soon all was good again and I have two struts ready to go back on the car.
The other job I had done was to push out and reinstall the diff bush the right way up ….I can’t remember which forum member spotted it, … but thank you for being eagle eyed.
I would have taken a picture of it being done but it happened so fast I didn’t get one, so I took this when I got home.
It also means this time I will assemble the gasket properly ( no sealant)
I also took some samples of my brake pipe bending and forming just to get confirmation that I was doing it correctly……and….
only It was pointed out that I have to put the fitting on first….
Oh, and
@Dino D, look what Lee was doing to your car…… attacking it with an angle grinder
You didn’t need that bit did you ?????
Nice to see Martin again, (
@Mnbrennan ) who came down to pick up some bits.
The only downside of the day was that
@pgunter wasn’t there……so we had to eat all the doughnuts
….Sorry Paul but they wouldn’t keep ……
I left Lee and Gaz working on Lee’s old Z3M, which at the moment looks like mine ( all in bits) but I’m sure it will be back together faster than mine.
