B
badman gee
Guest
Plenty of water to pump!
I'm a softy office worker. This kind of thing is not natural to me at all. I can hit things with other things and follow instructions, but it will have taken me 10 times longer than someone vaguely competent...Most you lucky guys get to do this type of thing and relatively enjoy doing it. To me it's a busmans holiday.
Are you sure it's the rad Richard? If your rad has side expansion tank it's worth checking bottom `O' ring area? New ring ~£5 - new expansion tank with O ring £20 to £30 cheaper than a rad!backed her out of the garage today oh no pool of antifreeze on the floor, new rad required hopefully with a complete new cooling system it will be all systems go again.
Took the plunge and just ordered the Stewart pump from Bimmerzone couldn't find a uk supplier and it came to £151 with shipping, a tad more expensive but what the hell i guess !!!
It's come with a lifetime guarantee so should outlive me !!
Sent from my iPad using Tapatalk
@Woody100, I am fairly certain you will have the plastic impeller, I changed my water pump in my 2001 model a while back, this had a plastic impeller. Nothing wrong with the old one when I replaced it, no signs of cracking etc but it gave me piece of mind.
How many miles on your car Brian?
Was it easy to change?
I would suggest making sure you have all the tools and parts to hand before starting (unlike myself) to avoid frustration. Worthwhile changing the drive belts and thermostat while your in there.Does that make me a wrongon !!!
