Right, so I’ve used the scanner tool, these are the codes I get with the engine off, I started the engine and now only have codes 41 and 08..
What should my next mode of action be?
Thanks again for all the help you’re all giving.
Connor.
Thanks Tony,Did you actually clear all the codes mate? If not you should, then run the car and re scan to see what, if any, has returned. Looking like Inlet cam sensor to me.
Thanks Tony,No mate two separate issues but if both come back you should check for air leaks around the rubber trunking between the MAF and the manifold.
Inlet cam senser is a known problem on many Z3s as the mileage gets nearer 100thou. Research tells not to buy cheaper ones as they don't last, oem is the way to go imo. The rubber inlet elbow has to come off to be checked properly, once off pull and stretch it at the inside and outside of the elbow as the cracks sometimes only show up under stress. Maf is easy check as @g8jka and @t-tony has told you. Good luck.
RHA, Roy.
Hi Tony, I'm gonna PM you as soon as I get a minute.Hi mate.
So this is why you have such a high post count!Hi mate.
