And so it begins again
Faheem
Leicester
1.9 M44
That is good to know @Sean d I will cut the sleeves before fitting.
billz
Langley Mill
Will look better than when it was new mate. Great job
Sean d
Lincolnshire
I'm hoping it will be rolling tomorrow pal, sick of seeing it on axle stands, then all I have to do is a colour change both interior and exterior, I really feel that the tough stuff is behind me, going to do the oils on the diff and box tomorrow.
Jack Ratt
TRURO, CORNWALL
2.8i AUTO and 2.8i MANUAL
You would be a YouTube legend if you filmed this job @Sean d
Bozzy
Long Eaton.
Great job Sean, you've done a huge amount of work on that zed and you're bound to feel benefit of it all once your behind the wheel.
I imagine you'll feel much better once it's off the axle stands as you mentioned :thumbsup:.
Looking forward to seeing it in September :whistle:.
Davyhoogy
Sunderland
'98 2.8 z3
Got the frame up and in place, it couldn't have been easier, up on a jack in one piece and it literally fell into place, however thats when I hit a problem, I fitted the brackets to the bottom of the main beam bush and tried to get the 8mm bolts in place, tightened the main nut only to find that the bracket was about 8mm to low, the only answer was to drop the whole frame and shorten the bush sleeves, too 8mm off each side put them back in place and wound them up, they have compressed really well and the 8mm bolts went straight in,
I spoke to Duraflex and he said that they are generic and will need cutting, load of darn if you ask me
View attachment 81991 View attachment 81993 View attachment 81994
Oh ffs, so I'll need to trim mine? Glad you done it first lol
mrscalex
Swindon & Swansea
Having done a not dissimilar amount of restoration during my 2.2 engine replacement project last year I know how many hours go into this sort of thing. Possibly some people would be shocked by just how much but it’s measured in low hundreds of hours not tens of hours. It takes over your life for several months.
So a major well done Sean, especially for sharing progress and informing and inspiring people along the way.
I know the elation you will feel when it’s back on the ground and then moving by itself.
But of course there is still lots of stuff to do even then.
Sean d
Lincolnshire
Thanks Robert, it is all consuming, joking aside I do lose sleep over it, I wake up early hours with the build going through my head and all the problems I may hit, I had set a dead line for today, that was for the car to be on its wheels, all was going great and by 1pm all I had to do was replace the oils and bleed the brakes, thought I'd get the brakes out of the way first, thats when disaster struck, I sheard off both rear bleed nipples, that bought me to a grinding halt, I tried drilling one and an easy out all to no avail, not sure what route to take now.
From personal experience Sean, the short answer is a pair of exchange callipers. I think it was Ant who found some at a good price?
ps. I have tried removing old screws over the years and have never been successful.
mrscalex
Swindon & Swansea
I can see if I have a pair which I’ll try and remove the bleed nipples from before sending.
Antm72
South Yorkshire
153062970436
These are the cheapeast i can find my bad thought it was fronts.
Be a shame to use it now.
I agree, and there was that lovely 2.2 up the road he could've got to actually drive . . . . . . ;)=))
