Hi,
Another problem another thread. After replacing my oil filter housing gasket and O-rings, i put everything back together, i replaced my rusted steering radiator loop,
and then refilled liquids and started the car.
A few issues i discovered after this.
1) Coolant leaking from the radiator plastic drain plug (i think). I will try to tighten it and try again.
Also radiator related problem, i drained a lot of coolant and i filled up, i was expecting the engine to run the pump and free up space for more but it didint.
Maybe because it didnt reach high temperatures because i ran it for 2minuted because of my other problems.
2) Grinding metalic noise from engine but most probably accssories. I think it may be the alternator bearing, i hit it with a soft hammer a few times to get it in place but it is old and it seems possible that it broke. Also may be the tensioner bearing/pulley thing that i am not sure how to remove without removing the steering pump bracket.
The noise gets worse with acceleration, i didnt move the car but i pressed the gas and it goes with the rpms if that makes sense. At first i thought the engine didnt have enough oil because i had just replaced it but it has a bit more than maximum that i may also need to drain a bit.
3) Hoses from steering fluid reservoir to cooling loop need replacing or i need to find a sealant that works better. But i dont think the noise is comming from a dry steering pump. Although the steering wheel makes noises when turning probably because i havent bled the system.
My solution i have thought so far is:
1) check drain plug on radiator and replace it.
2) lubricate alternator bearing and tensioner pulley see of this changes the noise. tensioner pulley is 50£ alternator 230£
3) increase torque? i only torqued alternator screws to 30Nm, a bit low but shouldnt cause such noise i think.
4) maybe replace hoses from steering reservoir to cooling loop. DCompared to my damages so far this is cheap cheap.
I will try and post a video of the sound.
I really appreciate any help or suggestion.
