never seen that one before, try reading EWS module again (get coding) , this will re-write the saved file on your computer.
Me neither just thought I'd give it a go. I'll pop the unit round to you then when I've stripped it down for solderingMe and technology aren't the best of pals Daz, but I can solder joints ok. Got to worth a go with your old unit.
I also can't just change the module as all the wiring is sealed. I would have to remove the red, black and twin blue wires running to the pump but not sure if that would work or not? I'll plug it in and run inpa see what I get.well i have to say, your module is completely different to mine, plug it back in, then run inpa and see what it says.
Remind me of the year/month of your car @Daz3 , I've had a look at the wiring diagrams for the pump and can find 3 options!!
If this was the case why is my inpa not talking to the abs unit or does something else need to be done? Will have a look later for build month it's a 1997 that's all I can tell you now. I have a multimeter ready so once advised I'll carry out the tests thanks for your input much appreciated.Another thought just entered my head, This looks like one of the older style pumps, the ABS ECU is not integrated in to the pump like the newer units, the bit you are trying to code is still on the car.
The ABS unit on your car will consist of the ABS pump and the ABS electronics, it seems as if these are two separate units on your car, on newer units these are combined, hence other members swapping the pump and re-coding, it maybe that there is nothing wrong with your old pump.If this was the case why is my inpa not talking to the abs unit or does something else need to be done? Will have a look later for build month it's a 1997 that's all I can tell you now.
OK this is interesting as the throttle body sensor signal to the same slip control module as the ABS.The asc throttle body is removed but still have the sensors etc plugged in. I was aiming to remove the unit that controls the cable for the throttle body at some point which involves putting a resistor in place from what I've read about it.
