If I do this upgrade all I need is the new 300mm disc and the bigger carriers right? I wondering if the callipers are the same then what happens to the brake pads? Do I buy the 300mm version of the brake pads because if I buy the old ones won’t I have the same braking because the same amount of surface will touch the brake pad? Will the 300mm version of the brake pads (if they exist - I am very confused ) fit in the old calliper? Any help appreciated
