Some parts are worth waiting the cheaper price for. I’ve used this https://www.bmwautoparts.net/en to cut down on ///M tax for some parts.
Handbrake cables I got from Sopers weren’t much over £25 with forum discount. Lots of choices for poly bushes but costing a bit more than oem ones.
was that each or for the pair?
That was for the pair.
Good man let me know if ya want anything for itAndrew, I will take the CV grease to the local PO on Monday.
Grease is on its way to you Andrew (5 sachets).
wow, did well there,
not sure how you wrangled that one,
Soper's just quoted me £22 each with forum discount, and when I said you had them £25 for the pair, he laughed and asked how long ago was that?
Best he said he could do was £19.98 each
Cv grease arrived today tony. Good man. Thatll get most of them back together thsi weekGrease is on its way to you Andrew (5 sachets).
Sorry just read what i typed. I meant to add i cant so all cause one of the caps is damaged. Need to get a replacement before can do itThere should be enough grease there to build 4 joints Andrew. They normally supply 1 sachet with a new boot. If you over pack them they will leak it out.
Beem quiet since before christmas. Life getting in the way. To avoid it sitting too long and me not having motivation to continue later on i thought best roll the sleeves up and do something.
Got stuck in with the dremel and wire wheel amd started rust removal. Once was happy with the result primed and sprayed.
Is getting to the "finishing" stage which is nice to see.
View attachment 168233View attachment 168235View attachment 168237View attachment 168239View attachment 168241
Soon the cheque book is going to have to make another few appearances
@Mazza hope you still have a few of those fuel straps left in a few weeks![]()
Cheers Tony. Its gradually getting thereShe's looking pretty sharp under there Andrew, well done.
