So Finally got the car up onto car jacks and got a look under her.
Shes had very little recent work done ill say that. I've a whole new control arm and bushing set and track rod set coming in the post. Will need to add break discs and dust covers to that list it would seem. might even change the suspension front and rear while im at it now. Had already considered swapping out the rear struts so might just put the money in and do it right.
Subframe is surface rust so a good brush down and POR15 coat should sort it out.
The exhaust will need replaced also. Those nuts are rusted to the point i was able to break them away to basically nothing with my hand. but besides that the exhaust system does look very aged and i want it swapped out.
I'm thinking for the main work as much as id like to do it myself it may have to go to mechanic. the rust on the nuts is worrying. I've PB Blaster which im going to soak it in but id be surprised if that will help. Will need to get these all replaced with new and ill be surprised if they wont need cut and bored out.
on the plus side the Chassis looks to be in good condition at least and engine is purring like a kitten.
They are all replaceable parts which is grand. Also think the engine mounts could do with being replaced. getting quite old looking.(not pictured) but again nothing i could do myself.
There is surface rust on the axels which im going to brush down and rust proof again.
Any suggestions would be appreciated. I don't know whether to be disheartened or not tbh.
Pictures:
