Zedshed West (Lydney)
Status
Not open for further replies.
Many thanks to Niall and Colin for their help today. It was a pleasure to see them and Gary and drink some coffee and talk b*******s. I’ve really missed it. A special thank you to Mazza, for all his hard work in developing and supplying the straps, which as Colin has mentioned, were on their last legs. Got to get me a new sensor now. Thanks again lads. :thankyou::scorecard:
Well what an easy job! @Mazza those straps are an engineering master class mate :thumbsup: and will outlast most of the zeds they are fitted to. Instructions spot on, only query, they say the main strap bolts are 13mm, on Phil's car they were 14mm, didn't take a great deal of sorting out that one though :whistle:=))=))
Sorry for the catastrophic mistake on behalf of Bognor Lean-to Enterprises.......it was based on the bolts on my car........but errors are errors, and I have given the technical illustrator his P45......:(
.I just hope the additional exercise of getting up off the floor to change the socket from a 13mm to a 14mm, didn't spoil the day.......:whistle:
Ruined my day mate :whistle: =))
Zedshed west closed this weekend.
Saturday 15th May Zedshed Lydney closed
Thanks for the notification. I'll never get a T-Shirt at this rate ;)
=)) sorry mate, got to remove a load of decking this weekend ready for the builders to come in and lay slabs and build walls, SHMBO will have my guts if I go AWOL. Should be on for the following Sat :thumbsup:
No problem Niall, if you need a hand shifting stuff, I may be able to help?
The new sensor has been delivered and fitted. I have also invested in new bonnet grills as the others were a bit loose.
Did you clear the codes after fitting the new camshaft sensor?
Will plug it in next time we see each other and clear them
You're getting a bit handy with the tools mate.:thumbsup:
Open for business this Saturday (22nd May 09:00hrs)
Ramps booked out AM
Off on a Canal Holiday Saturday so can't make an apperance this week.
Hopefully I will take a trip over and grace you with my presence :coolsteer)
Saturday 29th. Doors open 9am. Ramps booked out all day.
Status
