A small modification to the ramp oil drainer. Its needed doing since I made it, with the bowl having to be drilled off centre due to stiffening web underneath,
it was a bit saggy till the oil ran into the barrel. I decided to fit a support to the other side of the bowl using some alloy tubing.
I needed some thin rubber washers to seal the bolt in the bowl and made some out of a piece of bike inner tube with 6mm hole punched (cut) in it squashed between 2 big flat washers then trimmed with a craft knife.
Should make for easier draining on the next Shed day.
