#ZedShed Z4 Coupe Journal
The stock exhaust outlet and cat must sap a fair bit of HP and torque judging by how it looks - quite a fat pipe but a chuncky cat after that!
those branches you got a re are for LHD suppose?
They're RHD and do fit, just the steering clashes. They're from the 3 series.
Little coupe update. As I do alot of track days along with spirited driving I thought I would try out an RTD shifter.
Get the old girl in the air
you’ll need to remove the exhaust and propshaft. Remove the old two part linkage. Cut back a bit of the carpet.
get the shift central so the 3/4th throw is bang on central. You’ll need to drill 3 holes to bolt it to the tunnel.
I tried to refit the sound deadening but it would fit. So now I can hear the transmission slightly and get a bit of heat up the shifter.
Below shot showing the shifter bolted in using just one Linkage arm.
Now the shift throw is very short and being higher much easier to shift gear quickly.
then a track day to make sure everything works well :D
she’s such a capable car on track now, this setup proves you don’t need all the horse power to have fun and be really competitive on track.
Nice👍
  • Thank You!
Reactions: Lee
Rha
Z4 coupe sport.
Love the look of that shifter, in fact love the look of the Beast on track. Still not giving up on getting another.
Had a garage clean out recently and need to get a good home for some very usefull mainly Z3 spares. Will contact you on w/app if your interested ( no cost to the Z shed ).
  • Thank You!
Reactions: Lee
So the car has undergone another transformation. There’s now development work being done on the N52 engines and they’re all pushing above 300bhp Naturally aspirated. Me being me jumped all over this so the coupes gone through the first stages of development. She’s currently just shy of 280bhp with the next stage still to come. I also even got to stretch her legs at the Ring a few weeks ago.
first round of development by BDS is tweaking the valvetronic and fitting their custom intake.
few Ring photos. This is the clio we just finished building at the shed. Safe to say she’s a right weapon.
resting after some laps with a friends Z4M.
Standard Ring photo.
and some shots on track.
cool photo with the whole squad in tow. Also me completing the wipperman challenge cutting the curb
Dino D
Kent
2.8 Manual
Nice to see an update on this beast😎
I was getting worried when I only see pics of Gaz’s Audi on track…
300bhp out of 3l na is good going.
So a big update. After the new mapping went on she’s making between 280-290 bhp, but she also developed a start stop feature which is rather annoying. The revs dropped so quick the valvetronic couldn’t catch it and it would cut out, we spent a day trying to figure out what it could be. After spending a day out testing with the laptop we started noticing strange valvetronic readings and after a peak inside we could see the cam was goosed.
The master Bruno at BDS working his magic
Later when I got back to the unit I took a look at the cam
So the reason why this matters is the N52 uses the cam/valvetronic motor to control the valve lift at idle if the gear is over worn like above it has too much play. So today I collected the last cam BMW had in country with new needle bearings and shells. Thought I would give it a go fitting myself.
New valvetronic cam
luckily this cam is not a part of the timing so can be removed very carefully.
Old cam out
New cam in
When you compare the state of the teeth you can see the issue
Now I just need to get the mapping redone :D
Dino D
Kent
2.8 Manual
What would be the cause of that sort of wear do you think?
Always thought of cam loves wearing, but never gave a thought to the gears that turn them!
Age I would think mate. Not many coupe have reached this milage and I guess it depends how they’ve been used. This cam is constantly adjusting so fine tunes the idle etc.
So a long story short and not mixing my words I got messed about by BDS, the problem was caused by them trying to modify my existing map and causing chaos with my engine mapping. I called in a favour at RBM to flash my ECU back to stock and the car is now happy again. So 6 months of not having a correctly running coupes and spending literally thousands has left me a bit bitter about it. BDS won’t accept any blame so I’m having to move on and forget about it.
On a positive note though I’ve just done another trip out to the ring and she was faultless.
Spotted heading on for a few laps
Friend of mine chasing in his M2
official ring photos to follow. Coupe will now be off the road for a few months now, with 50+ track events and 168k on the clock she’s still on the original clutch so she’s getting a refresh.
elevensies
North Lincolnshire
roadster 2.8 widebody
had one just like that, i really shouldnt have got rid, but there we are......
was a great car on the road too, only disappointment, those wheels.... they were corroding on every bolt, and i couldnt find anyone who would touch them, saying the bolts sheer.
Reactions: Lee
I had a set of those wheels and stripped them myself. Only broke one bolt out of 80.
Thats a shame about BDS. 300bhp was an exciting prospect.
Worse that they have not admitted fault of any kind. Word travels fast around owners clubs.
It is a shame as they've done it to a few N52's now, I got tired with being messed about and not seeing my car for 6 months. As everyone knows I like to actually use my zed all year round.
Scooblitz
Glasgow, Scotland
Having a car for 6 months doesn't indicate confidence in their ability to perform the mods they are offering. Surely if it was honed, if would be a few days of dyno testing, at worst.
  • Agree
Reactions: Lee
