- Joined
- Feb 18, 2016
- Points
- 231
- Model of Z
- Z3M Imola and Z4 (e89)
Wish I had the balls to try this. Top job again Sean.
I am using acrylic thinners pal@Sean d what do you use to strip the old colouring from your seats ?
I have considered it pali always thought it would be cool to body colour the backs of the seats
Like the Z1?i always thought it would be cool to body colour the backs of the seats
When I had this issue with the aftermarket ones it turned out that one of the pins in the plug was bent so not making contact, baffled me until I decided to check, the plugs on them can be a bit naff so maybe it’s just that...Can't get the heat pads working on the passenger seat, they are after market and thought they would be ok, not got a multi meter to check but connected the power supply to a bulb and that lit when switched on so it looks they they are tossed, to my surprise I tried the drivers seat base and it worked a treat with the OEM ones
Wish it was that simple, I have bullet connectors on themWhen I had this issue with the aftermarket ones it turned out that one of the pins in the plug was bent so not making contact, baffled me until I decided to check, the plugs on them can be a bit naff so maybe it’s just that...
I'll sort a picIf you please send a picture of the connector I might be able to tell you what those connectors are about
If you are talking about the red and black wires going into the 2 pin terminal blocks with screws, they definitely are not a BMW fit. Either someone has fitted a wiring loom in to repair something, or to add something new.Had a good look at the seat today and there is nothing wrong with it at all, it was me connecting the wrong wires, the multi plug for the heat pads was just sat there in full view and I missed it and assumed the red and black wires where after market heat pads,
I plugged everything in and it works a treat,
So the question is, what are the red and black wires with the connector blocks
I still don't know what they are but they appear to be part of the loom@Sean d,
I am not sure if I followed your post:
No idea i'm afraidWhat year of car did the seats come out of?
