I've had a nice delivery today which may require some explanation for the record I'm trying to explain not talk down to anyone everyone's level of knowledge and understanding varies in different areas my wife's an accountant and I just nod and smile and make the right noises when she's telling me stuff about her work (if she reads this I'm dead)
so these are my new batteries
and these are my old batteries
Yes they do look very similar but these modules come in several different versions 1.5kWh 16s, 2kWh 16s and 2kWh 2p8s
If you've been following this thread you may remember that I had a problem with one of my 2 battery packs which turned out to be a problem with 2 cells in just one of the 6 modules as it's not a good idea to replace just one module in a pack I had several options
No cost option go down to 5 modules per pack which would reduce the pack capacity from 18.20 kWh to 15.15 kWh as they were 1.5kWh 16s modules
option 2 buy a new pack of six 1.5 kWh 16s modules at £1000-£1500 and keep my original planned capacity 18.2 kWh
option 3 buy a new pack of six 2.0 kWh 16s modules at £1500 + and increase my capacity to 20.2 kWh
option 4 buy 2 new packs of 6 six 2.0 kWh 16s modules at £3000+ and increase my capacity to 24 kWh
The other issue I had was fitting six modules in the back was extremely difficult but running 2 packs in parallel they had to be the same number of modules and this is where option 5 comes in
option 5 I was offered eleven 2.0 kWh 2p8s modules giving me 22.0kWh these were only slightly more expensive Than a pack of six 2kWh 16s modules and unlike the 16s modules which had to be run in equal numbers in the front and rear packs because these are 2p8s modules the whole lot is run in series and so can be run with 6 in the front and 5 in the back which makes things much easier where space is an issue in the back
also the maximum pack voltage will be slightly lower at about 369v compared to the current 398v this will make no difference the issue with using this option is it doesn't come with BMS slave units so I have to use my existing ones from my current 16s modules this is good and bad, good because I only need 6 slave units as the the modules effectively only have 8 cells as they are connected in parallel in pairs then 8 in series where as the 16s modules have 16 cells connected in series so would require twice as many slave units the down side is that I have to make adapter boards so that I can connect two 2p8s modules to 1 slave unit
Here's a little picture I pilfered off the internet that probably explains the 2p8s and 16s better than me the top one is 16s the bottom one is 2p8s
as you can probably guess I went with option 5 which is now stacked up on my garage floor
