- Joined
- Dec 8, 2011
- Points
- 145
@MisterP007 - It sounds like you did what I did and CUT the wires to the three dash console plugs (X16, X17 & X271). I left all the uncut wires connected to the plugs - this allows me to plug in the original console if I need to. There are enough wires uncut and still connected to allow mileage reading as well as SI reading and reset.
If I had planned it properly, I would have used parallel lines (soldered, not ScotchLok
) - then ALL the wires would still go to the dash console plugs. I may do this modification when I get the car back from Classic Coachworks.
Re the ETB fuel tank ballast resistor. I used a 47 Ohm resistor, not the 300 Ohm one that was supplied.
I was also able to fit a low fuel warning light, but I'm not 100% happy with it as the backing of the dial lifted and it shows a shadow. The light works, though
A top tip from me would be to use the BMW wiring diagram rather than a multimeter to trace the correct wires. The wiring diagrams are very good and even show what is going on inside most of the switches. (http://www.porterbility.co.uk/Z3_Wiring_Diagrams.htm)
) - then ALL the wires would still go to the dash console plugs. I may do this modification when I get the car back from Classic Coachworks.Re the ETB fuel tank ballast resistor. I used a 47 Ohm resistor, not the 300 Ohm one that was supplied.
