Thought this was interesting as it covers some of the questions that crop up on here from time to time.
View: https://youtu.be/hWijfooeSyU
Using this guy's thinking Brian, it must. All fairly common sense really. Educational info for those who need it.Interesting Gary thanks. I wonder if using wheels with different to standard offset has the same effect?
I with Tony on this, different offsets will do the same thing, it would be interesting to know the acceptable tolerance BMW built in. I use spacers on my car (no bigger than 12mm) but use a stud and nut kit, personally not a fan of the bolt on big spacers, don't know why but they just do not sit right in my head.Interesting Gary thanks. I wonder if using wheels with different to standard offset has the same effect?
We see that when over torqued equipment comes back from the rigs, we call it "belled box" on the female connection and "raised shoulder" on the male connection, the equipment can be scraped if a re-cut is not an option as you don't want stuff falling down a well, just as you would not like to see your wheel come off your car.Lastly never over torque bolts as you will induce permanent set into them, and the joint will come loose as the bolt continues to stretch under load. Use recommended torque figures where ever possible.
I very nearly lost both back wheels Tony, on a trip earlier this year i had a terrible noise coming from the rear of the car, I thought I had ripped the diff out, turned out that the previous nights spirited run had backed off the nuts. On inspection I lost 2 wheel studs and the remaining nuts were looseWhich, as I said, is why I use the higher torque figure. I still can't see where using slip on type spacers adds two "more" joint faces though Rich, surely it's only one more. I agree with your comment about avoiding it by not using any but that's just down to personal choice.
Just as a matter of interest, has anyone one here who uses spacers ever lost a wheel through bolts coming loose?
I don't hear many people saying that they have and spacers are a bad idea!
Thank you, now I understand the point that have raised.Each face counts as 1, so face of the hub and face of the wheel equals two, the clamp load stops these two faces from slipping against each other and vibrating the bolts loose, using a slip on spacer adds two more joint faces, so hub to spacer (2) and spacer to wheel (2). The later joint requires more clamp load to prevent it coming loose.
When I say loose, you would not be able to detect it by eye, or by shaking the wheel, it is at the micro level, see the link to a video below:
View: http://youtu.be/YRYYWQKh-bU
Under tightening is number 1 cause of joint failure when all parts are quality assured. You also need to ensure that all joint faces are dry and free of grease as this can lower the coefficient of friction of the surfaces and allow the joint faces to slip.
In the video, you see the nut coming loose, in real life on a wheel, the wheel does become loose once the bolt is loose and then you get bending moments, that lead to either fatigue failure of the bolt or the spacer being ripped apart. But the cause will have been under tightening,more in some cases over tightening passed the capability (elasticity) of the bolt.
