WATCH THIS SPACE...
David
Shoreham-by-Sea, West Sussex
Z4 3.0si Sport
@oldcarman It's a very simple solution to be honest, and I feel that the explanation won't do it justice, without pictures of the end result.
But in its most simplest form, here is the inspiration for the idea:
oldcarman
Canadian Zeds
Pine Falls Manitoba can.
View attachment 10198[/QUOT
David, is it based on the pull down mesh window covers that are used on the side and rear glass as in a window blind? I have four across my front window in my home to block the sun in summer. I'll try to send you a pic in a PM tomorrow if I get a chance. If so could work out! Keep at it, you'll figure it out! JIM
Dino D
Kent
2.8 Manual
How did this work it in the end?
David
Z4 3.0si Sport
...like many of my ideas, @Dino, it went on the back burner!
I've recently found the ideal mesh roller to use and they can be picked up fairly inexpensively, so I think I will look into it some more. The main problem I can foresee is how to keep the deflector firmly in position and tailoring it to fit the roll hoops.
FRANKIE
Is that a cupcake? Frankie
