Can anyone tell me what this is? A small circular (?) switch marked 0 - 1 - 2 between the steering column and the centre console. It also has a headlight motif with up and down arrows. It does not seem to do anything. Puzzled.
You'd have to be an ex-pat. Nah, an ex-pat would know that there is only room for one carton of lunatic soup and two bottles of overproof Bundy rum in the boot.That is your headlight adjuster, 0 being the normal position 1 & 2 for when you're carrying a Roo or crates of 4X in the boot. Prevents you blinding the Sheila's on their way back from the sheep shearing contest in their ute's..
What does it really do? It's a sort of "right said fred" thing.-- it doesn't seem to do anything. It couldn't be a missile firing switch, could it?Triple post
I suppose I might have to wait until dark time for it to work?Park the car facing a wall or garage door and move the switch with the headlights on, you should see the beam pattern move up and down very slowly when you operate the switch.
Oh FFS.My MOT tester said that this is now a fail item if it doesn't work, and it's retrospective regulation. If this is so, blanking plates will become valuable!![]()
Incorrect info Ian. The tester has to check the aim as the vehicle is presented, if it passes, it passes. IF it does not then the tester can adjust the switch to see if it will then pass, or not.My MOT tester said that this is now a fail item if it doesn't work, and it's retrospective regulation. If this is so, blanking plates will become valuable!![]()
I hope you are correct tony. My MOT tester is very reputable and switched on. Said it is a new requirement, think from May 2019? Sincerely hope he is wrong on this occasion.Incorrect info Ian. The tester has to check the aim as the vehicle is presented, if it passes, it passes. IF it does not then the tester can adjust the switch to see if it will then pass, or not.
